KL/VAGCOM Ignition coil test Does not work
makka
Post by makka »
On a fiat Coupe the actuator ignition coil test does not work
It say failed as soon as the test is pressed.
I have also tried the ELM327 Bluetooth interface with fsmobile
As it still fails
Bosch motoronics 3.1 ecu
Regards
makka
Re: KL/VAGCOM Ignition coil test Does not work
Post by makka »
Hi is this a bug or does the feature work ?
Regard
tzok
Post by tzok »
I understand you have engine off before executing this (and most of other) test?
