I want to replace the FIAT UConnect radio head unit in my X/290 Ducato vehicle & replace it with a different unit. I am told I will need to do a PROXI realignment after removing the unit to restore the date/time setting capability via the dashboard MODE buttons instead of via the head unit (as per an X/290 without factory fit radio) , however I have also seen suggestions I need to 'tell' the BODY Computer the vehicle now has an after-market radio fitted......
Can anyone confirm if this is the case, and if so how it might be achieved with MultiECUScan?
Brian
replacing FIAT X/290 UConnect radio head unit
Re: replacing FIAT X/290 UConnect radio head unit
I think if you change radio, you can not adjust the date and time, as in all cars with Uconnect.broc wrote:I want to replace the FIAT UConnect radio head unit in my X/290 Ducato vehicle & replace it with a different unit. I am told I will need to do a PROXI realignment after removing the unit to restore the date/time setting capability via the dashboard MODE buttons instead of via the head unit (as per an X/290 without factory fit radio) , however I have also seen suggestions I need to 'tell' the BODY Computer the vehicle now has an after-market radio fitted......
Brian
In 500, for example, those without Uconnect, the instrument panel software is different.
The old Stilo, Bravo and Delta were different.
I think it is possible with a PROXI realignment on MultiECUScan
Maybe you need to do a Custom Proxy (Ctrl+Alt+c) and know the byte to change
I'm trying the inverse, put a FIAT UConnect radio head unit with rear camera on my X/290 Ducato
