Use of MES
philbritton
Use of MES
Post by philbritton »
Please can you advise what is necessary to use MES on my laptop (running Windows 10) to be able to reset my Service interval data after carrying out an oil/filter change service? I have already downloaded an installed version 3.6 and bought the relevant interfaces together with a modified ELM adaptor, but cannot get past the "test" procedure as I always get a "timed out" message. My car is a Fiat 500C 2013 model and I am using the yellow connector. Your advice would be greatly appreciated.
NYC Eng
Re: Use of MES
Post by NYC Eng »
I have not used MES to reset my service changes but you can get rid of the light by following this procedure
1- Turn your key to the auxiliary ON position (One turn before start)
2- Fully depress the gas pedal 3 times
3- Turn key to off position
