Can you tell me what you mean on the backlight? Do you have the picture of the old vs new?
I believe this is the p/n
5SV93JXWAC
5SV93JXWAC
nufan0000 wrote:Can you tell me what you mean on the backlight? Do you have the picture of the old vs new?
Note the new rear lights. This tft is for restyling models and has the short menu.
Note the old rear lights. This tft is for prerestyling models and has the big menu.
For European models this is so.
That's not the european fiat code.nufan0000 wrote:I believe this is the p/n
5SV93JXWAC
It starts with 735
snowbound_sonic
Hi alex-et3,
Please could you check out these TFTs for me?
As per my original post I have a 2011 Abarth 500.
Is there not something in the Custom Proxy data bytes that can be amended in the same way that the value of Byte 65 can be changed to "60" for the Abarth graphics?
Many thanks
Many thanks
- 07-06-2016.jpeg (91.14 KiB) Viewed 93805 times
- 12-12-2016.jpeg (52.36 KiB) Viewed 93805 times
Hi!snowbound_sonic wrote:Hi alex-et3,
Many thanks
These odometers are both for 500 Abarth Restyling.
Unfortunately they have the short menu.
You can not change the menu by editing the proxy because it changes the odometer software.
PS:
The odometer of the first photo you took on ebay from smg.express.parts?
I bought the body computer of that 500 Abarth.
I bought because I did experiments.
snowbound_sonic
Thank you for checking.
The speedo in the first in the first pic with a manufacture date of 07/06/2016 is what I bought from a guy on eBay. He had it running in a 2013 Abarth which had a 2009 ECU and BCM. He said there were no issues with the time flashing and not being able to change it. The graphics he had on there (he sent me a video) were of the S4 with the rev counter inside the clack centre ring.
I'm not too bothered by not having all the menus - I just want the correct time/date and for the time to stop flashing!
snowbound_sonic
The first picture is how the graphics were when I received the TFT and plugged it in (car missing from the 'road').
The second picture is after I changed the byte in the Custom Proxy editor in MES (with G=meter).
- Before.jpeg (595.18 KiB) Viewed 93797 times
- My TFT.jpeg (469.88 KiB) Viewed 93797 times
Unfortunately, you can not do anything to adjust the date and time.snowbound_sonic wrote:Thank you for checking.
That TFT is for 500 Restyling and the date and time in that car set it from the Uconnect radio.
To adjust the date and time you should find a Uconnect radio to temporarily connect only to adjust the date and time.
Here you can clearly see your TFT is the model with a reduced menu.That's the Abarth 500 Restyling!snowbound_sonic wrote:The first picture is how the graphics were when I received the TFT and plugged it in (car missing from the 'road').
snowbound_sonic
So if I plug a Uconnect into my car into the standard A/B/C ISO audio/power connector, I would be able to set the date/time?
