Double_Faster wrote:Dear people,
I have a Brazilian Fiat Punto Attractive 2013/2014 and Multiecuscan 3.2. I bought generic Wifi OBDII V.1.5. I tested scan and receive "Magneti Marelli IAW 7GF Injection" ISO Code: CD 85 9E 8C 51. Ok, I conected but I cant conect in Service, I receive error ECU.. This is a resistor problem?
http://img.photobucket.com/albums/v497/ ... bucger.jpg
http://img.photobucket.com/albums/v497/ ... thxwus.jpg
http://img.photobucket.com/albums/v497/ ... k4apmj.jpg
http://img.photobucket.com/albums/v497/ ... p6hllo.jpg
Anybody can help me?
Thank´s
Is your interface with MES Komptibel?
Make times a interface Test with MES
It is compatible with MES remove R1 on the back of the board
and try again
remember, use yellow adapter for the service !!
Matrixcod wrote:I have a problem connect with my alfa 159 to service interval reset with this interface
http://www.jpeg.cz/images/2016/09/08/5yZL.jpg
http://www.jpeg.cz/images/2016/09/08/1GhWp.jpg
Can you connect to the engine ECU?
prevents a bridge resistance of the CAN bus protocols
is not present on your board
Make time a test with this app
https://play.google.com/store/apps/deta ... identifier
anonimo76
Post by anonimo76 »
Alfaeddy wrote:
anonimo76 wrote:hello, elm bluetooth does not connect multiecuscan. I removed resistance 121, but does not connect the same.
how to solve? Thank you.
http://i67.tinypic.com/2mfz11y.jpg
to give again and again the same questions without first answers
What car?
Which model ?
What control?
Which interface?
If the interface is installed?
Which driver?
And very important, the interface with MES is komptibel?
To check this is with MES Interface Test
or a smartphone app
Ciao!!
Alfa mito 1.6 - Diesel Bosch EDC16C36 CF5
http://i63.tinypic.com/ubpjs.jpg
It connects with the smartphone with Torque. It does not connect with Alfa Obd with smartphones.
It is not connecting with MES....
Your interface is Version V2.1
And therefore not compatible with MES or AlfaOBD
anonimo76
Post by anonimo76 »
:cry:
thank you so much Alfaeddy...... ;)
Matrixcod
Post by Matrixcod »
Test with mes
RESPONSE: ATZ
ELM327 v1.4
ELM327 v1.4
Questa interfaccia è compatibile con ELM 327 1.4! Dovrebbe collegarsi correttamente con tutti i moduli CAN.
The interface connect only engine correct.
Other ecu no...
kegless
Post by kegless »
Having trawled the forum until my eyes bleed from jargon I am having a connection issue I hope the kind folk on here can help with. I cannot find the ELM 327 bluetooth interface v2.1 in the MES interface scan. It is found and paired sucessfully with windows 10 laptop as bluetooth device "OBDII". I have played about with the settings and can only get something to come up on the COM5 port when I try and 'test' and it runs through the first commands and indeed recognises the ELM device and version number however it stalls on the Command: ATSPC timeout. Any ideas? I did also manage to pair the device with an android phone and tried torquepro and it failed to connect to the ECU aparently, also failed to connect with device and torque pro to a Peugeot 307.
I have a 2007 Fiat Ducato (250 version) 2.3L Diesel
MES Free v 3.2
Realtek Bluetooth 4.0 module driver & USB bluetooth dongle
Cheers,
Paul
Spa Doctor
Post by Spa Doctor »
kegless wrote:Having trawled the forum until my eyes bleed from jargon I am having a connection issue I hope the kind folk on here can help with. I cannot find the ELM 327 bluetooth interface v2.1 in the MES interface scan. It is found and paired sucessfully with windows 10 laptop as bluetooth device "OBDII". I have played about with the settings and can only get something to come up on the COM5 port when I try and 'test' and it runs through the first commands and indeed recognises the ELM device and version number however it stalls on the Command: ATSPC timeout. Any ideas? I did also manage to pair the device with an android phone and tried torquepro and it failed to connect to the ECU aparently, also failed to connect with device and torque pro to a Peugeot 307.
MES Free v 3.2
Cheers,
Paul
Similar to the problem i'm still facing paul... let me know if you have any joy - Although there are many more issues then solutions on here...
lonerunner
Post by lonerunner »
Please advice, i have one of those cheap ELM327 which is supposed to support all OBDII interfaces but i can't even connect to ecu on my Alfa Romeo 147, it connects on other cars like Seat Ibiza but not on Alfa.
Here are the details,
My ELM is exact name is ELM327 OBDII v1.5
But i can't even connect to ECU, when i try to connect, the window stays empty for a while while and than drops out with error, the thing is that my odometer flashes for a second and nothing more.
When i try to test interface i get this.
And device is connected and working with ch340 driver
Knallfrosch
Post by Knallfrosch »
I have a problem with Multiecuscan and my Interface.
I use this interface: http://www.ebay.de/itm/ELM327-USB-V1-5- ... 2883?hash= item33a5e111c3: g: 0OcAAOSw3ydVpMlp
The connection to the ECU works. Clear error in the ECU works.
When I perform SCAN (F11), comes the answer "DONE".
But there are no modules appear.
And when I select a parameter, the Connection disconnects completely.
The interface use the drivers: Prolific USB to Serial Comm Port 3.2.0.0 (Windows 10)
The setting in the device manager I have changed from 16 to 1
Does anyone know the problem?
Do I need to remove the 120 ohm resistor in the interface?
Thank you very much.
greetings
PS: The Test from the Interface:
RESPONSE: ATZ
ELM327 v1.5
ELM327 v1.5
