hello Galt
For the Alfa 159 you need only the green adapter to even the ABS is responsible for all other controls should be also be read without an adapter
The yellow adapter, you can not use, it is not for the Alfa 159
Which driver you installed ??
I had the reset the service an error has been also shown
but the provision has still works.
Hello abed
Very important !!!
What car?
Which model ?
What year?
Do you have an interface installed?
Have you adjusted the settings as described?
Which driver you installiiert?
I have min. 200 times linked the correct driver
writing only, does not work !! ??! ??!?
is something little
Very important !!!
What car?
Which model ?
What year?
is something little
i have a mitsubishi pajero 2001 shogun
i used torque app on android , it connected to wifi but keep searching for ecu protocols in tourqe app the blue car icon keeps blinking
didnt install any drivers just used torque i tried with windows 10 tablet but didnt work all connected but when it come to ecu it fails
im new to this i hope to learn
thaks for your quick replay
abed wrote:i have a mitsubishi pajero 2001 shogun
You know that this is about Multiecuscan and Italian cars here ??
Whether your Mitsubishi should be read with torque can tell you no one here
yes i know for adaptors, everything works fine on my car, CAN and body computer too, the problem is just with Service reset. I can read everything about it, but when i want to reset the service interval dash blink and MES says failed!Alfaeddy wrote:hello Galt
yeah i know ,but i couldnt find any other fourm
i guess i have a broken elm327
anyway thanks alot for your replays man
I have a problem connect with my alfa 159 to service interval reset with this interface
http://www.jpeg.cz/images/2016/09/08/5yZL.jpg
http://www.jpeg.cz/images/2016/09/08/1GhWp.jpg
Dear people,
I have a Brazilian Fiat Punto Attractive 2013/2014 and Multiecuscan 3.2. I bought generic Wifi OBDII V.1.5. I tested scan and receive "Magneti Marelli IAW 7GF Injection" ISO Code: CD 85 9E 8C 51. Ok, I conected but I cant conect in Service, I receive error ECU.. This is a resistor problem?
http://img.photobucket.com/albums/v497/ ... bucger.jpg
http://img.photobucket.com/albums/v497/ ... thxwus.jpg
http://img.photobucket.com/albums/v497/ ... k4apmj.jpg
http://img.photobucket.com/albums/v497/ ... p6hllo.jpg
Anybody can help me?
Thank´s
Thank´s
hello, elm bluetooth does not connect multiecuscan. I removed resistance 121, but does not connect the same.
how to solve? Thank you.
http://i67.tinypic.com/2mfz11y.jpg
anonimo76 wrote:hello, elm bluetooth does not connect multiecuscan. I removed resistance 121, but does not connect the same.
to give again and again the same questions without first answers
What car?
Which model ?
What control?
Which interface?
If the interface is installed?
Which driver?
And very important, the interface with MES is komptibel?
To check this is with MES Interface Test
or a smartphone app
https://play.google.com/store/apps/deta ... identifier
