I have the Interface Autodia K410 and i try to Connect to the Engine of an Alfa Romeo 156 2,4 JTD, but it don't work. If i do a Scan i got no result. But i find and can Connect to the Airbag und ABS. If i Look in the Support List it should work fine.
Can you help me?
KL Interface dose not found Engine
Re: KL Interface dose not found Engine
you have installed the correct driver ??
If I read it right you get a connection to ABS and airbag ??
Have you ever with the engine running is trying to connect ??
yes I try to connect but it dos not work and I try to scan the engine but I got no result.
Today I have update the Driver and the multiecuscan software but I got the same result.
Than I try to connect to the Engine with a ELM327 Adapter and it work fine.
Oh !!!!
With ELM, you can connect
only with the KKL it does not work ??
is Then I guess that your KKL defective
What does the interface test in Multiecuscan / settings because ???
Oh !!!!
