Hi Ripae,
problem still not solved ... actualy I want to try choose "OBD cabel" (but I realy have ELM327 cable) and try to connect with my 147 ... But now my bro borrowed it, so I'll try it in next week...
I speek only in english and Czech
I opened my ELM327 1.5a.......
http://www.ebay.es/itm/272307536185
and removed R2...nothing happened. I only can enter in motor module
Hello, i have same problemRipae wrote:I opened my ELM327 1.5a.......
I have a ELM327 "V1.5A"
No conection to CAN bus high speed
What chinese ELM327 should I buy?
Or how to adapt this one?
Regards
So, I tried to connect with my ELM 327 V1.5a, but still with no effect ... I can connect Peugeot 106 with another SW, but Alfa not...
I tried OBD and ELM setting, all speeds, many drivers ... Maybe I'd buy original ELM327 or another older (V1.3 od V 1.4) chinese one ...
I don't know what to do with cable I have ...
I elm327 version 1.5 is small. Do not read steering and body.
I can not attach a photo. Here is the link to the photo. What resistor should be replaced?
https://cloud.mail.ru/public/HbTC/pBjr5eNao
dimma_ wrote:I elm327 version 1.5 is small. Do not read steering and body.
I can not attach a photo. Here is the link to the photo.What resistor should be replaced?Code: Select all
which vehicle ?
which control ?
CAN Bus problem ?
Resistor R2
greetings Eddy
Fiat punto mk2 188 1.2l 16v 2002y.Alfaeddy wrote:dimma_ wrote:I elm327 version 1.5 is small. Do not read steering and body.
which vehicle ?
which control ?
CAN Bus problem ?
Resistor R2
greetings Eddy
It is only connected to the engine
for the Punto 2002
you should without removal of the resistor R2
come to your motor control
Is your interface with MES compatible ??
To read the ABS - green adapter
To read airbag - KKL Interface
Remove R2 - for other control
for the Punto 2002
Hello guys,
i have just the same problem like the this guy:
"I just got an Chinese ELM 327. When I connect it to my Alfa 159 using the Green adapter, I can read the Engine fine. Even resetting the faults works. But when I try to connect to the Service using the Yellow adapter, I get a connection error. Using the green adapter, I can connect just fine to Service too, but when I try to execute the NEXT SERVICE KM RESET, the screen in the car briefly flashes off and it fails." The interface works great without any of adaptors and read CAN, just when i want to reset anything about service and screen on the dash flash briefly and MES says "Failed to execute" Anything?
Thank you
Thank you
Hello all
This is my first time writing, I read another in this but couldn't find answer
I have elm327 wifi and I can't connect to ecu
Do I have to remove a resistor???
Or just it's a broken and can't be fixed
