help to build interface cable
mek_control
Post by mek_control »
I'm new Here and i want to use multiecuscan with my AlfaRomeo 156 but here In My Country it's hard to get interface cable so i appreciate if you help me build one
thanks in advace
Re: help to build interface cable
I would advise you to buy an interface on eBay, but if you want to build it yourself just Google the internet and you will find a lot of different forums that provide detailed informations how to build the interface.
Just keep one thing on your mind if you are planning to build the ELM327 interface it requires ELM327 chip. So before you start to build the interface go to internet and search parts that you need and then go to local electronic shop to check the parts.
Good luck! ;)
tzok
Post by tzok »
Simple single bidirectional K line interface:
http://surfnet.dl.sourceforge.net/proje ... ISO_KL.png
To be precise the jumper selects between unidirectional K+L (green) or bidirectional K (blue).
mek_control
thanx 4 u guys but i need some one who try one
i didn't wnat to make something wrong
