PROXI ALIGNMENT Steering Lock Node (NBS): EOL Failed
toka0005
Post by toka0005 »
I have just about tried everything to get the PROXI ALIGNMENT to work on my Alfa 159 2.2 JTS but i keep coming up with the following error during the alignment procedure:
I know that the steering lock is active from the CAN info and i also physically tested it out and there is no problem with it.
Can anyone make any sense of all this?
Here are the logs:
CANinfo
2015-05-18 19:21:05
CONNECTED TO:
Alfa Romeo 159 2.2 JTS 16V
CAN Info
List of configured control units :
Body Computer Node (NBC): Present
Engine Control Node (NCM): Present
Electric Steering Node (NGE): Not present
Dashboard Node (NQS): Present
Steering Wheel Controls Node (NVO): Present
Receiver Radio/Radio Navigator Node (NRR/RMN): Present
Brake System Node (NFR): Present
Info-Telematic/Convergence Node (NIT/NCV): Not present
Driver Door Node (NPG): Present
Boot Node (NVB): Present
Climate Control Node (NCL): Present
Automatic Transmission Node (NCA-NCR): Not present
Steering Angle Sensor Node (NAS): Present
Parking Brake Control Node (NPB): Not present
Ceiling Node (NIM): Not present
Side Acceler./Yaw Node (NYL): Present
Adaptive Cruise Control Node (NAC): Not present
Passenger Door Node (NPP): Present
Driver Seat Node (NAG): Not present
Assisted Braking Node (NBA): Not present
Passive Entry Node (NPE): Present
Steering Lock Node (NBS): Present
Gearbox Selector Node (NSC): Not present
Passenger Seat Node (NAP): Not present
Parking Sensor Node (NSP): Not present
Engine Signals Node (NSM): Not present
Airbag Node (NAB): Present
Air Suspension Node (NMA): Not present
Roll Control Node (NRC): Not present
Self-adaptive Headlamps Node (NFA): Not present
Haptical Lane Feedback Node (HALF): Not present
List of active control units :
Body Computer Node (NBC): Active
Engine Control Node (NCM): Active
Electric Steering Node (NGE): Not active
Dashboard Node (NQS): Active
Steering Wheel Controls Node (NVO): Active
Receiver Radio/Radio Navigator Node (NRR/RMN): Active
Brake System Node (NFR): Active
Info-Telematic/Convergence Node (NIT/NCV): Not active
Driver Door Node (NPG): Active
Boot Node (NVB): Active
Climate Control Node (NCL): Active
Automatic Transmission Node (NCA-NCR): Not active
Steering Angle Sensor Node (NAS): Active
Parking Brake Control Node (NPB): Not active
Ceiling Node (NIM): Not active
Side Acceler./Yaw Node (NYL): Active
Adaptive Cruise Control Node (NAC): Not active
Passenger Door Node (NPP): Active
Driver Seat Node (NAG): Not active
Assisted Braking Node (NBA): Not active
Passive Entry Node (NPE): Active
Steering Lock Node (NBS): Active
Gearbox Selector Node (NSC): Not active
Passenger Seat Node (NAP): Not active
Parking Sensor Node (NSP): Not active
Engine Signals Node (NSM): Not active
Airbag Node (NAB): Active
Air Suspension Node (NMA): Not active
Roll Control Node (NRC): Not active
Self-adaptive Headlamps Node (NFA): Not active
Haptical Lane Feedback Node (HALF): Not active
PROXI ALIGNMENT
CAN CONFIGURATION DATA:
04 32 97 7B 04 32 97 7B 04 22 01 4B 00 00 04 01 00 00 00 00
04 32 97 7B 00 22 05 09 04 32 97 7B 00 22 05 09 00 02 05 09
32 31 31 34 30 30 30 32 38 31 38 4F 55 54 50 55 54 2D 4A 49 54 20 06 03 13 7B 97 32 04 09 05 22 00 83 6D 00 07 B7 00 14 10 00 06 95 06 01 00 00 06 08 00 00 22 50 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 45 00 02 00 00
Boot Node (NVB)
Teg Reader Node (NTR)
Airbag Node (NAB)
2015-05-18 19:20:12
CONNECTED TO:
Body Computer Node (NBC): EOL Ok
Engine Control Node (NCM): Ok
Dashboard Node (NQS): EOL Ok
Steering Wheel Controls Node (NVO): Ok
Receiver Radio/Radio Navigator Node (NRR/RMN): Ok
Brake System Node (NFR): Ok
Driver Door Node (NPG): EOL Ok
Boot Node (NVB): Ok
Climate Control Node (NCL): EOL Ok
Steering Angle Sensor Node (NAS): Ok
Side Acceler./Yaw Node (NYL): Ok
Passenger Door Node (NPP): EOL Ok
Teg Reader Node (NTR): Ok
Airbag Node (NAB): Ok
Heimertagg
Re: PROXI ALIGNMENT Steering Lock Node (NBS): EOL Failed
Post by Heimertagg »
It is very interesting.
Edson maia
Post by Edson maia »
Bom Dia verifica se existe algum desgaste mecanico na suspensão, e sistema de direção.folgas nas ponteiras . jiuntas homocineticas, desgaste de pneu irregular, cambagem, alinhamento .se tiver algum corrija depois limpe os erros da memoria . e ele ira destravar.
