Fiat Ducato 2.3 Marelli 8F3 CF5/EOBD DIESEL INJECTION (2.3)
Good morning, I bought a multiscan eur 50.00 for scanner only one car Van Fiat Ducato 2.3 multijet economy 2012/2013 to DPF regeneration and clear the oil change light of the engine, to my surprise the program opens all other models of van Fiat Ducato (244) and before but when I try the Ducato (250) Facelift 2.3 Multijet ECU Magneti Marelli 8F3 CF5/EOBD DIESEL INJECTION (2.3) come whith error connection ELM 327. what can be? i use the ELM 327 V1.3.
Re: Fiat Ducato 2.3 Marelli 8F3 CF5/EOBD DIESEL INJECTION (2
i am facing the same problem, i can diagnostic cars only when key is on mar, if engine is running, it is not possible to connect.
Can someone confirm this?
Hi! I am facing similar problems. All scaned units unknown. I needed it to remove tail light diagnostics (it is available in simulation) body control module is even not available in free mode. Until late modules is unsupported there is no point to bay full version!
