Hello R1taka
Ja, R04 is the right Resistor
djakon999 wrote:Other side is very difficult to caputre good quallity photo
http://i63.tinypic.com/1z23p5w.jpg
http://i65.tinypic.com/294p8o0.jpg
While it's not your interface
but the same construction boards
Sorry, I can at the moment not insert images
This appears to me.
"Sorry, the board attachment quota has been reached."
We had the board been here
djakon999
Post by djakon999 »
This appears to me.
Hello, please upload image to other server like imageshack or tinypic. You can also give me page number of this tread where it was.
m1taka
Post by m1taka »
Alfaeddy wrote:Hello R1taka
Hi Eddy,
Unfortunately, it didn't work. I've remove the R04, but there is no change - I can still connect to the engine only. Any other ideas?
Regards, M1taka
Hello M1taka
To which vehicle is located ????
Such information is also important
bozza
Post by bozza »
HI
i am haveing problem with elm 327 obd bluetooth adapter i got from aliexpress (2 of them). When i connect adapter to car obd (fiat bravo 2012, 1.6 mjtd) dash board instrumets go crazy. Fule and temp guage goes to 0 and i got massage on dash display that parking senzors are unavailable, also something about airbag. Thing is the same when try to connect to Stilo 1.9 JTD. It reads Renault Megane III and Duster with no problems. I tried with removeing bridge rez but it behaves the same. Any suggestion ?
Here are the link to elm and picture of board
http://www.aliexpress.com/item/Super-Mi ... 21578.html
http://www.aliexpress.com/item/2014-Top ... 41617.html
http://postimg.org/image/uepmf25m1/
i removed circuled rezistor
Hello Bozza
It is important that you set a screen of Interface Test here.
There are many interface that no longer work with MES.
The ELM for € 6.85 I also do not run with MES
Information about Megane and Duster are useless because you can not read with MES these vehicles.
And this is about MES (Multiecuscan)
m1taka
Post by m1taka »
Alfaeddy wrote:Hello M1taka
Eddie,
The car is Alfa Romeo 156 Sportwagon 1.9 jtd, Prod. date: 14/6/2002, the ECU is EDC15C7, like this one: https://ecu.co.uk/alfa-romeo/engine-con ... 02073.html
I hope this info helps.
Regards, M1taka
Hello M1taka
Thanks for the information, the sooner to knowledge would be an advantage was
Because
Needs to read a Alfa 156 with MES the bridge resistance not be removed because the Alfa 156 has no CAN bus.
Your interface should work just as well without modification with MES.
Is your interface at all compatible with MES ??
Which driver you installed ??
Make a test interface with MES and put a screen here.
Those are always the same questions I here first of all has to find out ;)
bozza
Post by bozza »
Alfaeddy wrote:Hello Bozza
i will post scr from MES, i am just wodering is that cind of behavior with dash board normal, i mention Renault just to say that adapter work with other cars and software
