Hello guys,
I'm new here and I already red whole thread. You are doing great job! Unfortunately I didn’t' find my OBD device (ELM327 Bluetooth mini) modification.
So, I'd like to mode my ELM327 because it won’t work with my Alfa 159 and ECUScan 3.6.2.
I'm receiving:
OMMAND: ATZ
RESPONSE: ATZ ELM327 v2.1>
RESPONSE: ATI ELM327 v2.1>
RESPONSE: ATE0 OK>
RESPONSE: OK>
RESPONSE: OK >COMMAND: ATSPC
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: ?>
RESPONSE: ?>
RESPONSE: ?>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
I’ll be grateful to you if you can help me with modification? Here are pictures of my device and if needed I can unsolder upper circlet board to get pictures from inside.
Thx in advanced for your help.
- IMAG2906.jpg (816.68 KiB) Viewed 8932 times
- IMAG2902.jpg (1.12 MiB) Viewed 8932 times
- IMAG2890.jpg (1.42 MiB) Viewed 8932 times
But your interface has already been repeatedly described here !!
The Interface v2.1 not operate with MES or AlfaOBD
Unfortunately, I do not know any of the current to be purchased Mini ELMs the
are kopatibel with MES.
But I purchased it from ebay as "Mini ELM327 V1.5 OBD2"...I'm not so deep in this topic to see differences, but probably you see on pictures that I received newer version; Am I right?
Alfaeddy wrote:Hello
Alfaeddy wrote:Hello Mitix
Unfortunately, your image is not very clear
But if I am right should be on the back of the bridge resistor R2.
And make time a screen from the MES Interface Test, and please put the one here
let's see if MES can work with this EL
Because now there are many interface that can no longer work with MES or AlfaOBD
hi .. OK i think this pictures clear..
and interface test ...
connect to motor but dont connect other s
RESPONSE: ELM327 v1.5 >
ELM327 v1.5 >
OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
- 20150907_221431.jpg (188.97 KiB) Viewed 8926 times
- 20150907_221013.jpg (189.32 KiB) Viewed 8926 times
pls help me which resistor is destroy? r2 ?
and Should I make 6-1 / 14-9 / 7-12 ?
- R2.JPG (85.46 KiB) Viewed 8926 times
mitix wrote:pls help me which resistor is destroy? r2 ?
This is the right one
kk159 wrote:But I purchased it from ebay as "Mini ELM327 V1.5 OBD2"...I'm not so deep in this topic to see differences, but probably you see on pictures that I received newer version; Am I right?
Hello KK159
Unfortunately, the traders also do not know what software was burned to the PIC.
The dealer is also hereinafter referred to as the manufacturer's specifications
I also bought Interface V1.5 but get the version v2.1
And these have given back and get my money back.
thax a lot ... İ did . OK...Alfaeddy wrote:mitix wrote:pls help me which resistor is destroy? r2 ?
Thx Eddy!
Alfaeddy wrote:kk159 wrote:But I purchased it from ebay as "Mini ELM327 V1.5 OBD2"...I'm not so deep in this topic to see differences, but probably you see on pictures that I received newer version; Am I right?
Hello KK159
I want to ask something . I changed the license plate lamp and LED daytime lights. but it is burning lamp failure. ı want disable fault lamb
