Can key be programmed using Bluetooth ELM327 or it need to be cable?
[img][img][/img][/img]hello I have an equal its already removed the resistor 121 and could not communicate with the ECU , could u can help thankful
- elm 327 usb.jpg (482.19 KiB) Viewed 9058 times
someone help have a this elm 327 retired already resistor 121 and anyway I can not communicate with the ECU so with precise engine starts reset service my car has the pins 4.5.7.8.16
- elm 327 usb.jpg (482.19 KiB) Viewed 9059 times
Hello Anderson
Which car?
Which model ?
What control?
Which car?
Which model ?
What control?
Fiat Ducato multi 2.3 diesel /ano 2014 / tomada elm 327 usb
Hello Anderson
I send you a PM
I send you a PM
Likewise to most of these posts having issues with anything but the engine module on an Alfa MiTo.
Thanks!
Matt
Thanks!
Matt
ola essa e foto test elm 327 eddy
- elm 32 7
- teste 1.jpg (692.06 KiB) Viewed 9039 times
eddy essa segunda foto test
- teste 2.jpg (758.94 KiB) Viewed 9039 times
Alfaeddy wrote:Hello Anderson
I send you a PM
- teste 2.jpg (758.94 KiB) Viewed 8952 times
- teste 1.jpg (692.06 KiB) Viewed 8952 times
