Hello Paulik
no Grüß Gott, I'm not a Bavarian :D
In both images, Dortmund and your I can not see anything.
Does not matter.
Power times with MES test and adjust the screen here.
fefe128
Post by fefe128 »
hi, please what resistance should be removed to let me go all the controllers on FIAT STILO 1.9JTD multivagon 2007 and Alfa romeo giulietta 2.0 JTD 2011 ? Figure in Annex
Thank you very much
ELM 327 1.5a
ELM 327 1.5a
Remove the red marked Resistor
file markiert.jpg (596.28 KiB) Viewed 8972 times
fefe128
Post by fefe128 »
Hello, thank you it's better to get almost all controllers. But I can not get on Airbag, Electric Power, ABS FIAT Stilo 1.9JTD Multivagon 2007. Can also start these controllers?
the Alfa Romeo Giulietta 2.0JTD 2011 I do not :(
vince59
Post by vince59 »
Finally I found the proper adapter to access all modules and I was able to reset service and oil filter warning linght.
I only have the problem the MULTISCAN does not show the date and reading for service even if the reset works and light disappears.
I had problme resetting the warning light with MES 3.6 and I had to go back to MES 3.3
Can anybody help and give suggestions?
Thank you
fefe128
Post by fefe128 »
Adapter and what is it? on what kind of car?
ade739
Post by ade739 »
Hi Vince 59, which adapter did you use? I have a 1.6 bravo mjt and can only access the service light reset but not the oil service reset using the red elm obd link cable. The alfa 1.6 mjt i did earlier this year, also a 2011 like the Bravo, used the obd red cable plus the yellow A3 interface?
fefe128 wrote:Hello, thank you it's better to get almost all controllers. But I can not get on Airbag, Electric Power, ABS FIAT Stilo 1.9JTD Multivagon 2007. Can also start these controllers?
hello
Of course, do not you come with the Elm to the airbag
For this you need a KKL interface and red adapter (A2)
What is "Power Elektric" I can not translate = MotorECU?
For ABS of course you need the green adapter ;)
On Giulietta only the yellow adapter is needed
I thought this should be understood by the list "Supported Vehicles"
vince59 wrote:Finally I found the proper adapter to access all modules and I was able to reset service and oil filter warning linght.
Thank you
Which car?
Control?
I've also had problems with oil change reset at a Giuletta.
When Marelli ECU you have to enter the date in the English way,
mm.dd.jjjj
And at the Bosch Motronic in German position
dd.mm.jjjj
Different as shown in the MES.
fefe128
Post by fefe128 »
I ELM327 bluetooth as I modify it so that I can diagnose all the control units?
FIAT Stilo 1.9JTD multivagon 2007 and Alfa Romeo Giulietta 2.0JTD 2011
