Hi Alfaeddy:
I would like reset the maintenance service alarm and I have this ELM327 wifi
I have an Alfa 159 Jtdm 2.0 sport 2011.
What can I do?
Details of ELM http://www.aliexpress.com/item/2014-Hig ... 33302.html
regards
What can I do?
regards
- image.jpg (1001.74 KiB) Viewed 8103 times
- image.jpg (1.02 MiB) Viewed 8103 times
Remove the Resistor in the red Frame
then you can read the CAN Bus from your Alfa 159
Thanks Alfaeddy, I will check it.
Regards
Regards
What should I remove from this ELM to have acces to ABS and everything else (besides the ENGINE)? Is that the resitor, between the CAN lines? Thank you.
- 20150703_104420.jpg (1.2 MiB) Viewed 8088 times
ello
First of all, what vehicle you want to read ?????
Because very often have connection problems not related to the bridge resistor.
The red marked from you is the bridge resistor Resistor
I want to read ABS (and the other ECUs) on Alfa 156 1.9 JTD 16v, year 2004.
edit: I'll try not to do stupid questions
Thanks, Regards.
Thanks, Regards.
Hi Eddy,
I don't have connection problems, I understood that if you remove some resistor you may be able to read all ECUs (ABS, engine, Airbag, climate etc). That's why I am asking
Would it be better to use a switch and connect all the pins as described on the diagrams on multiecuscan? 7 for engine, 12 for ABS etc etc?
Meinten Sie: Hallo IHr Babuin Also bei dir ist es kein Verbindungsproblem Für das ABS musst du den Pin 7 auch Pin 1 legen Entweder mit Adapterkabel oder mit Schalter Und dein 156 hat keinen CAN Bus , daher brauchst du den Brücken resistor nicht zu entfernen. Kannst du aber tun , es bringt keine Nachteile Und wenn du einen Schalter einbaust , solltest du darauf achten das Pin 1 + 9 nicht mit anderen Pins verbunden ist. Damit du bei bedarf , auch Giulietta oder Mito die komplett über CAN Bus gelesen werden. Auslesen kannst. Gruß Eddy
Hello IrBabuin
So with you it is not a connection problem
For ABS You have the pin 7 also set Pin 1
Either with or adapter cable with switch
And your 156 does not have CAN bus, so you need the resistor bridges
not to remove.
Can you do but, it brings no disadvantages
And if you einbaust a switch, you should make sure
the pin is 1 + 9 is not connected to other pins.
So when you need, also Giulietta or Mito read completely via CAN bus.
Can read.
Hello IrBabuin
not to remove.
Can read.
OK, thanks AlfaEddy, I will use a switch to conect the correct pins to serial converter
I dig now the modification, for CAN vehicles you remove the termination resistor (120ohms) and the signals pass through to ELM-type chip. Neat.
