Icar 2 - Vgate wifi
RickAbarthgp
Icar 2 - Vgate wifi
Post by RickAbarthgp »
Hi there,. When you think you know somethjngs for sure you always spot a few thing that get you confused,.
I bought this great Vgate icar wifi(supports al obd2 protocols, at least that is weitten on the box,.
I have been usung it with dashcommand on my iphone 6 and that works flawless,.
Here is a link to the manufacturor's site,..
http://www.vgate.com.cn/en/iCar%202%20WIFI-239.html
Is it possible to connect to (almost)al ecu's?
If so do I need the adaptor kabels to get the interface completely workung with mes
Hoope to hear something soo ,.
Getz from holland
Re: Icar 2 - Vgate wifi
I still do not understand exactly what you want to do because
1. MES does not run on Iphone, it requires Windows.
2. What kind of car, model and year, control you want to read?
3. To be able to read the various controls are also required different adapter cable comes on to the vehicle to which you want to read
4. Not all controllers are equipped with ELM to read for some (older) needed a KKL interface.
5. Whether this interface with MES running you need to determine the connection test.
RickAbarthgp
Hi there,.
I tested the conection and that was good,. Al oke,. But I want to access my can- buss system but when I try I gwt a message that The connection failed with the ecu,. Wich adapter cable doI need to get a connection? .
Ooh right,. Forgot to say but I drive a Abarth grande punto 2009,. i dont think being dutch should have problems with this,.
Grtz rick
