MES not show Body Computer Marelli (2 or 3) parameters. (No show Parameter tab)
In other software (AlfaOBD) I can see the parameters below:
Front left door: Open
Rear left door: Closed
Front right door: Closed
Rear right door: Closed
Motor bar NC driver side: On
Motor bar NC passenger side: On
Motor bar NO driver side: Off
Motor bar NO passenger side: Off
Left indicator: Activated
Right indicator: Not activated
High beam headlights: Not activated
Hazard lights: Not activated
Boot lid: Closed
Automatic light switch-on: No
Heated rear window: Not activated
Rear fog lights: Not activated
High-beam headlights: Not activated
Brake fluid level: Normal
Parking brake: Activated
Fog lights: Not activated
Inertia switch: Not activated
After-market anti-theft: No
Door lock/unlock button: Off
Stop lights: Not activated
Reversing light: Not activated
Key position: MAR
Alternator status: Not recharged
This is a great feature to include in MES.
Parameters on body computer marelli
Re: Parameters on body computer marelli
Body Computer Marelli MF (present in Fiat Stilo) display all parameters fine.(Show Parameters tab)
But shows invalid ISO code when I try to connect my vehicle that has the body computer marelli (2).
Thanks,
This is OK in MES 2.4
