FES won't connect with Adapter Cable 3
Re: FES won't connect with Adapter Cable 3
Post by Waltomatic »
1) What module in which position are you trying?
2) The dip switch is properly installed?
Racing Man
Post by Racing Man »
Here's mine:
Racing Man
Waltomatic wrote:1) What module in which position are you trying?
Yes the dip switch is correctly installed... It simulates an adapter3 to connect with the can info, body computer, etc.
With my 147 GTA works fine, but with my wife's 500 twinair I can read only the engine, abs and electric steering...
Actually on my Alfa I wasn't able to connect with the xenon unit (in that case, the dip switch simulates the adapter1, as seen on MES website)
OK, you read correctly your Alfa because the CAN line of your Alfa communicates the original interface, WITHOUT adaptation. So your dip switch has no effect with it. But the Fiat 500 does require adaptation (ELM C19). So if your dip switch is installed correctly even, I think you need to review the topic told by yani for correct circuit change.
Racing Man
Waltomatic wrote:OK, you read correctly your Alfa because the CAN line of your Alfa communicates the original interface, WITHOUT adaptation. So your dip switch has no effect with it. But the Fiat 500 does require adaptation (ELM C19). So if your dip switch is installed correctly even, I think you need to review the topic told by yani for correct circuit change.
I don't understand what you mean for "correct circuit change"... Anyway, on my elm327 the resistor between can lines is already removed, directly from the seller, as you can see in my picture
Racing Man wrote:I don't understand what you mean for "correct circuit change"... Anyway, on my elm327 the resistor between can lines is already removed, directly from the seller, as you can see in my picture
Dear Racing, what I meant was exactly right (remove the resistor if necessary) since you did not pass this information before. I just did not look at his picture because I had not known this component visually ...
Racing Man
Ok, I was thinking that there was another change to do in the circuit after the resistor removal, if that wasn't working... :oops: So, how can I fix my problem? :D
Frankly I believe that adaptation may be wrong, see that to simulate Adapter Cable 3 you need 3 switches (6-1, 14-9, 7-12). If you show a picture of your connection we can check.
Racing Man
Waltomatic wrote:Frankly I believe that adaptation may be wrong, see that to simulate Adapter Cable 3 you need 3 switches (6-1, 14-9, 7-12). If you show a picture of your connection we can check.
No, the connections are correct, I've checked many times... I could even show a picture, but it's a little messy inside, and in my interface the cables are all in the same color... :cry:
I'll try anyway... I'm marking the pictures with some arrows...
Racing Man
In the picture don't mind switch #7, is orange but it's the pin7, and I need it to connect on my Alfa.
For my problem with the 500, just consider switches 1 to 6.
Copia di IMG_0971.jpg (1.15 MiB) Viewed 8452 times
Copia di IMG_0966.jpg (1.08 MiB) Viewed 8452 times
