Post by Waltomatic »
Gentlemen, I have seen the many problems they have faced with the ELM327 interfaces, especially some that seem more sophisticated. I have given here my reports and I only advise to look for the simplest (v1.4 or v1.5), and where possible give preference to cable connection. I bet you will be more satisfied.
Hello Dodo
I do not know this interface
Do you have data on this interface ???
Which operating system do you have on your laptop ??
Which driver do you use ??
And the motor controller and the ABS of your Alfa 159 have no CAN bus
So should connect to these two controllers + ECU (ABS = Adapter1)
without changing the board be possible.
tasmo
Post by tasmo »
i bought elm327 v1.5a
have Fiat Punto '02 1.2 16v sporting and only module that found is Engine,i have to conect to Delphi electric steering.what i should do whit cable so it can enter delphi and other modules on car.also cd with drivers came broken so i dont know if i have right drivers for cable
tasmo
Post by tasmo »
driver for usb that windows install is prolific USB-to-serial
tasmo wrote:driver for usb that windows install is prolific USB-to-serial
IT DEPENDS!
My Silicon Labs interface uses Silicon Labs driver, each interface must use your correct driver. For the electric power steering Delphi does not need any different connector (http://www.multiecuscan.net/SupportedVehiclesList.aspx) but have registered Multiecuscan.
tasmo
Post by tasmo »
this is only reading i get from car
tasmo
Post by tasmo »
gaspoia
Post by gaspoia »
I'm new to this forum but i have the same problem as some here.
The elm327 is the same as blkid and it connects to the pc and phone just fine but not to the ECU, it says it's unable to detect the protocol.
The only thing different is a wire connecting both r5 and r3 to U2.
The car it's a 2003 Nissan Almera.
Can someone please guive any advice?
Best regards,
Hello Tasmo
Your pictures are not good because you can not read components
Search the MCP2551 chip or TJA 1040 and make the environment
a better picture
The driver you get here
use the 2.10.00
Or this for silicone Labs USB ports as Walter already wrote
http://www.silabs.com/products/mcu/Page ... ivers.aspx
Hello Gaspoia
This is about Italian cars and Multiecuscan
With this software you can not read on your Nissan
Therefore, no patina must be changed.
Use a software package for Nissan
