Problem with reset after oil change with Qubo 1.3MJ
pinez
Post by pinez »
Hello everyone, I have a problem.
I changed the oil in my Qubo 1.3 MJ and appeared the notice that says to change the oil.
I connected the software to my car and I did the "Next service KM reset", but unfortunately the warning disappears.
I entered the exact date "Last service date" but nothing has changed.
I want to point out that the connection with the car works perfectly, because I managed to change many other parameters.
What could have happened?
Thank You
Re: Problem with reset after oil change with Qubo 1.3MJ
Post by s130 »
Generally with modern Fiat diesel engines fitted with DPF filters the "Oil Change" is separate Engine ECU function from the "Service" computer functions.
For your Qubo connect to the Engine ECU and then go to the "Adjustments" tab. There you will find the Oil Change reset function.
pinez
Post by pinez »
this is the problem ... I have the choice between three ECU, but I can not connect to any of the three because it gives me error .... but for the rest I can do everything without problems ... how can I do?
EDIT: I finally found out how to fix it!
While for all other operations I have to use the adapter 3, to connect to the ECU does not have to use an adapter, but you have to directly connect the OBD.
By doing so, I managed to connect to the ECU and reset the alarm.
Thank you very much!
JeremyDoum
Problem with reset after oil change with Qubo 1 3MJ
Post by JeremyDoum »
I have the same problem. I tried with both /tmp and HOME_USER/tmp directory. Second one with 777 permissions.. ANy idea how to fix it?
