The needle on the fuel gauge stuck at 3/4 even if the fuel tank is filled to the maximum, I think I can fix with multiecuscan but don't know what the correct voice for it and how do I test it
My car is Lancia Musa 1.3 MJ 90 CV (2007)
Thank's
How can I calibrate the fuel level
Re: How can I calibrate the fuel level
Hello robi73
I do not think the levels of fuel gauge can be calibrated with a diagnosis software.
In this software, I know this by any model
Because the indicator for the average consumption has nothing to do with the level indicator !!
Hi Alfaeddy
I did the test with Multiecuscan and lancet fuel moves up and down, but only to the point where it stops usually, that is 3/4, that's why I thought it was a problem of lancet
Hello Robi73
This function in MES is only capable to
To test fuel gauge function
No calibration is thus possible
Only Yani you can probably tell what the display values for the Test
is established in MES
The problem can be with:
- fuel gauge which is located in trunk, or
- lever on dash which schows how much fuel you have does not work.
