Post by Waltomatic »
Well, Bigio, this interface is not dead. Very ill, perhaps ...
I do not know if I can help but I'd like to see two screen prints:
1) "COM ports" in the device manager
2) list of existing ports on MES
LX522
Post by LX522 »
my Interface is not working properly as well and I could not find any pictures of this unit. Do you have any clue which resistor I should remove? Thank you :)
hello
Of course we have this interface already described here !!!
Should actually be be found on the last pages.
And unfortunately you write not about what the error.
But that make many users here
therefore what is not to read.
Very often there are settings or installation error
and not always the bridge resistance
Which vehicle?
What control?
Which protocols?
If it is a CAN bus problem remove the marked resistance
and try again.
I could picture your not with the program "Paint" open therefore as .pdf
Mini ELM markiert.pdf
(306.91 KiB) Downloaded 768 times
LX522
Post by LX522 »
Thank you very much. There are some similar looking devices but i couldn’t identify mine. Sorry…
I’m trying to connect my Alfa Romeo 159 to FiatEcuscan. I can connect but not enter the dashboard. I already wanted to throw it away when i found this forum.
Bigio80
Post by Bigio80 »
Waltomatic wrote:Well, Bigio, this interface is not dead. Very ill, perhaps ...
Here what you ask me. I'm nearly sure that ELM 327 USB Cable based on CH340 chip haven't never work with MES.
Someone have this cable (and see in device manager) and can work with MES?
Hi LX522
For your vehicle CAN Bus is necessary only ABS and engine ECU with
read another protocol. To which you should already now be able to connect. ?
No Bigio, lists like these...
burak5
Question
Post by burak5 »
Sorry for a a question which maybe was asked by someone else.
My Question: If I remove this resistor, will I loose any other feature for
using it with another car which isn´t a ford or with another program like scanmaster elm?
for example the can bus feature for other cars? :)
Second Question: Why you dont collect all variations of chips in a new thread? :D
@ burak5
#1 - Yes you will not be able to use your new modified ELM interface without resistor with other software like scanmaster.
I did test few ELM interfaces and they do not work with scanmaster 4.3... :D
#2 - I already suggested Eddy he should open some kind of "sticky" topic where we can only see interfaces and solutions to repair them.
But topic in which other members can not write their posts except from Eddy when he need to add new solution or new ELM board...
Moderators should help also...
zippo
Post by zippo »
Hey Guys, i get the interface in pictures. Which resistor i need to remove? Thanks.
http://www76.zippyshare.com/v/49371738/file.html
http://www14.zippyshare.com/v/6496294/file.html
