alfa romeo 156 1.8 TWINSPARK 2001
ALFAMAN
Post by ALFAMAN »
I want to reset the airbag warning light and abs lights on this car. Which version of ecuscasn do I need to download and can someone please tell me step by step the way to do it? Thanks
Re: alfa romeo 156 1.8 TWINSPARK 2001
Hello Alfamann
This goes with any version of Multiecuscan
you need a
KKL interface
and red adapter
- Install the software
- Install KKL Interface
- Install FTDI driver
- Check the settings
- Connect to the airbag controller.
- Read error
- Fix error
- Read and delete errors
- Same on the ABS control unit
only with green adapter
Yep! Eddy is right!
You need a KKL interface and MES.
I think you can clear airbag errors with free MES version.
ALFAMAN
Post by ALFAMAN »
tHANKS FOR THESE HELPFUL POSTS. BUT i'M NOT THAT COMPUTER LITERATE . WHAT IS A KKL INTERFACE AND RED AND GREEN ADAPTORS AND WHERE DO I BUY THEM FROM PLEASE?
ALSO, I'VE ONLY GOT ACCESS TO 2 OLD LAPTOPS ONE IS AN ACER 3690 AND THE OTHER IS A COMPAQ. WILL THE INTERFACE AND THE ADAPTOR FIT THEM PLEASE?
THANKS A LOT
Hello Alfaman
I can understand that your knowledge of the use of Multiecuscan
not yet know much
But for that you need to have something to read
on these pages you will find some of this
http://www.multiecuscan.net/HowToUse.aspx
If you have XP and normal USB port on those laptops MES should work.
Also KKL and ELM interfaces should work without problems.
Just install FTDI drivers (http://www.ftdichip.com/Drivers/VCP.htm) and NET framework (2.0, 3.0, 3.5 and 4.0).
ALFAMAN
Post by ALFAMAN »
I downloaded the ecuscan software and an icon appeared in my desktop, then I clicked on that and a box came on the screen saying it was preparing to install, but then it stopped another box appeared saying the system cannot read from the device. What's gone wrong I didn't have any interface plugged in??
First time to hear it. Strange... :shock:
I never had problems during installation of FES/MES... Really strange... :o
I did 2-3 times re-installed new windows XP on my laptop and every time did install FES/MES later on without any problems...
Sorry I do not know what could be a problem...
