I would like to know what I have to have before buy the software. I already bought an elm327 usb inteface (not modified) and the yellow adapter.
I'm trying the MES free version.
I get this error when I try to connect to the can module: connection failed elm327->ecu connection failed
I can connect to the engine magneti marelli module.
The drivers settings seem to be good.
Any suggestions before buy the software and don't have my problem solved?
Thank you guys!
Grande punto 1.2 CAN Connection
Re: Grande punto 1.2 CAN Connection
Camon guys! I can not buy the software if nobody tell me if I nedd something else!
Hello Capirex87
Which driver did you use?
Find the driver that Windows itself
or on the enclosed CDs
are very often outdated or not useful
Take this
Take this
And? Does it work? Did you tried it with new driver from Eddy?capirex87 wrote:Camon guys! I can not buy the software if nobody tell me if I nedd something else!
Hi, I use the driver from the cd.
I'm gonna try your drivers and I will let you know.
Solved by removing the famous resistance!
capirex87 wrote:Solved by removing the famous resistance!
congratulation
