ELM 327 connection
Crombel
ELM 327 connection
Post by Crombel »
I have tried 2.0 with the ELM cable and I get a TIMEOUT message.
Is the configuration (Latency Timer) of the serial port the same as for the VAG cable?
Crombel
Re: ELM 327 connection
Post by Crombel »
I have tried several settings but I cannot get connection.
Every time I get time out.
It works fine with k-line cable but not with the ELM327 cable.
Could this be a bug?
My car is a Fiat Croma '06 1.9 MJET 8V.
hanzs
Post by hanzs »
Hi, I have no problem with my ELM327cable on my stilo.
What cable do you have? Is it version 1.3+? Did you try to change baud rate in settings? My works fine with speed 38400.
Crombel
Post by Crombel »
Thank You!
As Simple As That, changing the baud rate in settings to 38400 solved the time out message.
Works great now.
Thanx again,
Dirk
testariauto
Post by testariauto »
Your ELM is working on all modules? (abs, airbag, engine, etc) or is still need to made movment between pins (3, 7, 1 ,9)
hanzs
Post by hanzs »
Yani wrote:
ELM 327 v1.3 SUPPORT! The program now works with 2 types of interfaces - VagCom and ELM 327 v1.3. There are limitations for both interfaces - VagCom does not work for CAN modules, and ELM 327 does not work with some of the older modules (like the airbags) and that is a limitation of ELM 327 v1.3. The newer versions of ELM 327 v1.4+ does work with those modules, but I don't have support for that interface yet.
It works ok for all ABS modules, except ABS 5.3, and also works for TRW EPS.
oem
Post by oem »
Hello yani, i try to connect with ELM327 1.5a to Alfa 156 1.8 with M1.5.5, but connection been time out. Where is the problem? ELM Version?
O.E.Motorsport - tuning & innovation
juanpa
Post by juanpa »
yani wrote:It works ok for all ABS modules, except ABS 5.3, and also works for TRW EPS.
With or without brige pins?
EnIgMa
Post by EnIgMa »
i read on another topic here that you still have to bridge pins...
@oem:
did you try to change baud rate? latency time?
does it work with other software?
