Car is Alfa 147 16v mJet 2003 EDC16 CF3/EOBD
I have the licenced version of MES and am trying to code the injectors, but am having problems.
I can connect with BT elm327, wired elm327 (genuine elm) and also kkl Vag409 to the ECU and read functions etc.
I tried recoding the injectors and get message saying success on each type of interface but when I go back to the injector again it has not changed the code. It still has the old one.
Why does it not work
Coding injectors
Re: Coding injectors
Did you resolve this problem ?
Yes, the code does not update in the programming interface.
It does, however, show the new code under F4 (Parameters)
