Your problem is not the 120 ohm resistor
For thine Panda will not be read with the CAN bus protocol engine
If you get no connection with your Panda 1996 is this
to the settings or the wrong driver
'll try this driver!
possibly, is also your motor control is not supported by MES.
But I do not know exactly
Check the first time the driver and settings.
Panda 500
Post by Panda 500 »
Thanks for the info. I'll try to download the other driver (although I'm only basic in computer stuff...)
But we have a Fiat Idea 1.3jtd and a Brava 1.2 petrol in the family too. I checked on the Brava and that one has the 16 pin connector like on the ELM327. Should I remove the mentioned 121 ohm resistor in order to connect to those more recent Fiats ? As you can see on the picture (see my previous mail) this ELM seems quite updated, with two different circuit"clocks" (I think that is what the silver boxes 4000 and 12000 are?), also the LEDs are SMD, and no more the "big" ones. But the 121 ohm resistor is still present.
svene
Post by svene »
I bougth a ELM 327 1.5 ( USB version )
Can you show me wich resistor i have to release?
elm 327 1.jpg (1.05 MiB) Viewed 7693 times
Best regards
Svene
Hello Svene
The red marked resistor is responsible for the CAN Bus Problem
remove this and your ELM can read logs with MES also CAN bus.
What control to which vehicle you would like to read and write?
elm 327 1 markiert.jpg (427.59 KiB) Viewed 7690 times
Hello Panda500
On your ELM Interface it is the same Resitor
svene
Post by svene »
Thank you. I gues it could be the marked 121 resistor,but I was'n sure so thanks for your fast answer
At the Moment I only want to reset the Service at my Fiat Punto Evo 1,3.
Greetings
Svene
jj747
Post by jj747 »
Hello everyone, I bought this interface obd2 wifi unfortunately I can not through "torque" and similar programs to connect to the ECU of my 2000 Volvo v70 2.5d, can you help?
Thank you
Stay mad and behave like normal people.
Are you sure the "Torque" can read your Volvo?
And here described here applies only to Multiecuscan
Out of Torque
You have another problem, not the resistor
neogenissis
Post by neogenissis »
Hi Everyone
i down loaded Multiecuscan V1.8 afew days ago, i currently have a ELM327 V1.5 bluetooth
same as this : http://www.ebay.com/itm/ELM327-v1-5-Blu ... eb&vxp=mtr
now im trying to connect to a 2000 fiat Palio 1.2 8v ecu code IAW 49F (south africa) how ever i cant get connection to ecu.
im using an obd to fiat 3pin adapter cable.
please can you maybe point me in the right direction to troubleshoot the problem.
jj747
Post by jj747 »
@ Alfaeddy the program is compatible "Torque" but it does not work read the ECU, the clone in my possession can recognize the version?
thanks for your patience
Hi jj747
Which program is compatible with Torque?
You mean the interface?
I'll also want to just tell it this problem with the bridge resistance
does not occur in torque.
Therefore, you would not have to open your ELM
