I just bought the license, but I can not connect to "Lancia Ypsilon 1.2". He's only the two front airbags. I tried to use all ECUs in the list but does not work.
I have Multiecuscan 1.8, KKL and red adapter.
Where am I wrong?
Lancia Ypsilon 1.2 / Airbag
Re: Lancia Ypsilon 1.2 / Airbag
Hello alfaalex
Can you because without red adapter, connect to your engine ECU?
Have you checked the settings?
Did you install the correct driver?
What controls are found when you press F11 (SCAN)?
Because the connection should work already.
but I can not connect to Diablo 3 Gold "Lancia Ypsilon 1.2". He's only the two front airbags. I tried to use all ECUs in the list but does not work.
Diablo 3 Gold
Buy Diablo 3 Gold
diablo3fast.com/
Diablo 3 Gold
Buy Diablo 3 Gold
diablo3fast.com/
Without red adapter, I connect to the engine ECU without any problems. Only airbag does not seem to work. The adapter works on another car (Alfa 147 1.9 jtdm)Alfaeddy wrote:Hello alfaalex
