Just bought a license, Airbag ok, Engine unable to detect
T0m
Post by T0m »
Car : Alfa Romeo GTV Phase 2 V6 2.0 TB
Cable : ODB2 TO USB.
PC : Win 7 x64
http://www.ebay.co.uk/itm/MultiECUScan- ... 417bcd84c0
resetting the Airbag light worked without any problem
but i am not able to connect to the ECU of the engine... , when i scan i get no results.
i alreay tried setting the latency to 1 on the com port but no difference.
what is going wrong ?
T0m
Re: Just bought a license, Airbag ok, Engine unable to detec
Post by T0m »
I can also connect to the Climate control and ABS, its just the Engine that does not want to connect :|
What happens when you set up your interface on pin 7 (KKL/ engine) and click on Scan (F11) button?
Does the system find some kind of engine ECU?
T0m
Post by T0m »
it finds no ECU,
it just Scans and says OK at the end.
i already checked the interface cable and soldered an extra wire from Pin7 to make sure it has a good connection.
So probably your engine ECU is not supported yet...
