hi Alfaeddy in the red circle there is an R04 resistor.
- P1010006 (Large).JPG (281.99 KiB) Viewed 7099 times
- P1010002 (Large).JPG (285.93 KiB) Viewed 7099 times
Hi, samebody can help me ? I bought the elm 327 bluetooth and it's work fine with motor module but when I try to connect to the body module the error connection appear. I use fiat multiecuscan 1.7
THANKS A LOT !!!!!!!!
Andrea
Andrea
- 20140221_154350 ridotta.jpg (379.9 KiB) Viewed 7097 times
- 20140221_154412 ridotta.jpg (361.9 KiB) Viewed 7097 times
My elm is here v1.5 bluetooth. İ want to modifications this elm and i want to open cruise control. My car is fiat linea 1.3 95hp 2013 euro5
Hello Gieboue
Thank you for the better picture
Remove big the resistor R04, in the red frame
Hello Andrea
Even with your interface the resistor R04 is the problem
Remove R04 (red frame) and your interface will work
Hello Juanito
Your picture is unfortunately very blurry.
I can not see any numbers on it.
Do not hesitate to a better picture of the area in the red circle
Hello again
not red circle in my elm v1.5 bluetooth. I remove r04 but i cant activate cruise control again. Thanks.
thanks Alfaeddy i'll try it.
Hi Alfaeddy,
thanks for the answer ,
I have removed the resistor R04 but the problem is the same..
do you have another solution?
thanks !
Andrea
thanks !
Andrea
andro58 wrote:Hi Alfaeddy,
I have removed the resistor R04 but the problem is the same..![]()
thanks !
Andrea
Hello Andrea
The red marked resistor is already correct
If your connection still does not work it may be the only driver to adjustment.
Just try this driver
