Alpha Romeo Sele speed, can I do? In what way a tester?
Air vent of the accumulator fluid (It is not a vacuum)
Re-movable accumulator
Reset the transmission computer
Please let me know.
Car, Alfa Romeo GT 2.0JTS
alfaromeo sere
Re: alfaromeo sere
as far as I can understand from what you wrote, I guess you want to service your Selespeed on your ALFA Romeo by doing:
oil bleed to remove air
change accumulator
cancel the parameters in the selespeed ecu.
First of all you need an ELM327 with MES registered. Then you can start the bleeding procedure by entering the function in the program and by loosening the screw allowing the oil to get out togheter with the air. Once there's no air anymore you can tighten the screw again.
To change accumulator you have to depressurize the system, otherwise you will face a very angry 50bar pressure oil!!
To reset ecu parameter just select end-of-line procedure following requirements to do it in the program.
change accumulator
