Hello  I have a problem ... I have a good 2007 version sports mjet 150hp I mounted an instrument panel matrix taken from another good year but always the same version Tjet sport ... I found that to open the door on the dispaly panel does not display the logo fiat as with all other matrix framework ....
Alignment and went well with multiecuscan you wonder if you can fix or need to reset the whole picture ...
Thank you very much ....
							The instrument panel
Multiecuscan registrato
Multiecuscan Mobile 1.0.1 su Samsung Omnia i900
Re: The instrument panel
And the car is (brand, model)?
Fiat Bravo 2007 mjet versione sport
And few more questions:
- is your car "mjet" (diesel)? and
- donor dashboard was taken off from "tjet" (petrol)?
Yes....
When I was opening before BODY ECUs from Alfa 147 I could see a difference between diesel and petrol BODY ECUs...
So I guess maybe this could be a problem...
There is a file to be loaded on the instrument panel as it is managed by a software
no solution to the problem
