Punto ECU not found
Punto ECU not found
I have connected my laptop and selected a car from the list but no matter which vehicle I select it returns 'ECU not found'. My 1.2 Active 8v is not listed thus I am choosing any vehicle on the list.
Has anybody any knowledge of how to overcome this prob lem please?
Re: Punto ECU not found
Can you connect with other ECUS (systems) like ABS, airbag and others?
If your car is not in the list of MES than probably it is not supported...
But other systems like ABS, airbag and others should be more-less on the list.
By the way which year is your car (Fiat Punto 1.2 8V)?
Thanks for responding so quickly. The year is 54.
Are you sure about this year or you are joking with me?toomyling wrote:Thanks for responding so quickly. The year is 54.
alfa156sarajevo wrote:Are you sure about this year or you are joking with me?toomyling wrote:Thanks for responding so quickly. The year is 54.
But wow this is a very old control
54 is the UK registration plate date number.
In this case (54) the user's car was registered a new between 1 September 2004 and 28 February 2005
Ok, that one can not know if you do not live in UK
But does this mean that the Punto in September 2004 to February 2005
Has been registered or is the Punto made at this time?
No basically the 54 plate date means that the vehicle was FIRST register in the 2004/2005 timeframe.
The vehicle could have been manufactured in say 2003 and stood around the docks / dealers for a year or more before being sold an registered.
Also in the UK it is possible to transfer licence plates BUT a license plate can not make a vehicle look younger than it actually is. You can not put a current 63 plate on a 2004 vehicle but you can put a 54 plate on a 62 vehicle.
Current plates are described here: https://www.autocheck.co.uk/NumberPlate ... Years.html
In the UK to my knowledge, even going back to early 1900s you could not have a custom number plate, e.g. "my car", and even if you could they are very very very rare. For custom plates over here one has to buy a registered plate off another person or the DVL (UK licensing authority). The DVL keep valuable registration off general circulation so they can make more money at a later date.
So people go looking specific number plates e.g. as seen here: http://www.fiatmotorclubgb.org/forum.ht ... 05979/show
e.g. F1ATS
If Alfaeddy wanted an Eddy registration then you could have: http://www.newreg.co.uk/search/search_r ... index.html
Always remember !!!
The price of vanity, personalisation is high but the price of MultiECUScan which is far more useful is low!
e.g. F1ATS
Always remember !!!
Thanks for clarifying that. Now it makes more sense...s130 wrote:54 is the UK registration plate date number.
I have the same type of car; Punto 1.2 8V, only my car is a MK2a (1999 - 2003).
I use an ELM 327 Bluetooth version, the circuitboard notes 'ELM327 ver 1.4a'
I removed the R04 resistor as Argo wrote in the 'de-mystified' topic. Since that moment I can use my phone with Torq app and read active, during driving. No errors shown.
When I use my laptop with multiecuscan it doesn't find the ECU. When I scan for connections, it detects a KKL line and testing the connection shows all is ok.
When I try to find the ECU, I keep getting notified: 'No ECU detected, check connection'
What to do? Or does the ELM need to be fixed for KKL communication?
Sorry for putting my situation in an active topic, but since this topic already is about a Punto 1.2 8V and without a solution...
ELM 327 V1.4a Bluetooth
Fiat Punto 1.2 8V MK2a
