Problem with Lancia Kappa Airbag
Hallo from Bulgaria,
I have problem with Lancia Kappa 2.4JTD at 1998 appears a error massage about JIT debugging and I cant delete the error
Can someone help me what I've to do ?
Please see the attachment files I made some screen shots
- Kappa.jpg (142.3 KiB) Viewed 11108 times
- kappa error2.jpg (162.57 KiB) Viewed 11107 times
- kappa eror.jpg (170.43 KiB) Viewed 11108 times
the patriot
Re: Problem with Lancia Kappa Airbag
hi did you get anywhere with this as I get the same on my alfa 156 2.4jtd airbag
Steven
Steven
It is a bug in the program. Will be fixed in next release.
the patriot
Excellent thanks for the Reply Yani, Ive been pulling my hair out trying to check the settings on my PC etc....
Look forward to the next release, do you know roughly when this will be out?
Thanks again
Steven
Thanks again
Steven
What are your exact settings on my usb does not want to ever add to bag my 1998 2.4 JTD engine is just fine thank you
usb kkl?
- IMAG0305.jpg (979.84 KiB) Viewed 10869 times
the patriot
Hi there not sure what your showing / asking here?jurki888 wrote:What are your exact settings on my usb does not want to ever add to bag my 1998 2.4 JTD engine is just fine thank you
I have joined pin 3 with pin 7 of my lead without the dip switches as i have not yet sussed out exactly how I will make the connections for them inside the lead?
Dropped the ESB port settings to lowest rate as per instructions and hey presto i have communication with both Engine and airbag ecu's
Steven
the patriot
HI guys,
did V2.2 fix this for anyone as i still have the same problems?
Maybe i have a setting or PC issue?
Steven
Steven
I did make a fix, but the problem still exists in version 2.0.... Hope to have it fixed in 2.1...
I have the same problem with Multipla 1.9 jtd, programm Ver. 2.1, and can't connect with engine, only ABS work properly
