marinozacc wrote:yes i want to encoding the trasponderAlfaeddy wrote:Hello
What Punto you?
What Year?
For the models from year 99
can the remote control via CAN bus are programmed.
http://www.ebay.de/itm/260754573911?_tr ... EBIDX%3AIT
Or do you want to program the immobilizer?
This is only possible with AlfaOBD
it's possible with multi ecuscan too?
thanks for the link , but i'm confused .. autodia327 is the same elm327?
and it will work on ford fiesta (2006) and alfa romeo 147 (2000)??
thank you a lot!!
edit: for example this
http://www.ebay.it/itm/V1-5-ELM327-OBD- ... 48a&_uhb=1
read the same protocol of autodia327.. change anything?
Hello Marinozacc
No, this interface will not work.
because it has this bridge resistor with the Multiecuscan has problems.
The interface in my link has been so transformed by the seller, according to my information so that it works with Multiecuscan.
Most others need to be changed, as described in this thread.
With Multiecuscan you can not store a transponder.
I think this goes on with AlfaOBD Punto not, but I'm not sure
for my Alfa 156 I can do with AlfaOBD
