In relation to this guide for manual clutch rod adjustment found on alfaowner.com
http://www.alfaowner.com/Forum/alfa-147 ... adiag.html
And in that the first step:
1, Load up Examiner or Alfadiag and select the "Selespeed" ECU, connect and then go to the "Sensor" tab, in the drop down menu select "Clutch Adjustment Position" and check the position on the graph. If it is outside of 28 - 28.5mm then continue, otherwise your done.
Which is the similar parameter (name of parameter) to look out for in Multiecuscan when performing this?
-Clutch pressure plate reference?
-Gear/Engage position?
Kindly
/Ola W
Clutch rod adjustment
Re: Clutch rod adjustment
Note to self:
Do a better search on the forum before posting new topics!
viewtopic.php?f=5&t=1174&p=3127&hilit=clutch+rod#p2956
Seems to be Clutch Pressure Plate Travel
Besides what is stated in the guide referred to above... Is there anything else one should keep in mind when performing the manual calibration?
I have heard rumours about additional manual/mechanical calibration procedures on the Sele.
Anyone who knows more about this?
