The resistance i wrote,it's a 2ohm restistance,put on the connection baloon of airbag.This is for don't cause a explosion of it.
For my problem.....what can i do?
Kkl interface don' work on airbag
Re: Kkl interface don' work on airbag
OK, now I understand what you mean with the resistor
But for that I give no answer
a variety of reasons
But this has nothing to do with the connection to the airbag control unit!
But only if you've narrowed down the problem to connect.
Just few more infos...
Even if it is written in MES web page that your airbag ecu is supported by MES it does not mean that your airbag ecu is 100% supported.
In general there are few types of airbag ecu's for same car and year...
So MES can read one but other can not read... Sometimes you can access to airbag ecu and there are no errors but still red airbag lamp is ON in dashboard...
Ok guys!
I surrender to do diagnostic with my airbag!!!
Thank u very much for the support
