Boris wrote:....
Yes I have tested it after removing resistor and it works OK
Did you instaled any other drivers for WiFI?
Do you have a web link which shows how your interface looks like?
How is your WiFi called (wifiobd ili wifi327)?
I tested my wifi and still does not work with mes 1.4 version...
Why did you inserted a bare wire after removing the resistor????
I have nowhere as described
And a paste of a resistor (100 ohms) and capacitor (560 pF) is not necessary,
Since the board is equipped differently than the original version of ELM Industries
Remove the connection have the added resistance of 120 ohms
then it should work.
I just got an Chinese ELM 327. When I connect it to my Alfa 159 using the Green adapter, I can read the Engine fine. Even resetting the faults works. But when I try to connect to the Service using the Yellow adapter, I get a connection error. Using the green adapter, I can connect just fine to Service too, but when I try to execute the NEXT SERVICE KM RESET, the screen in the car briefly flashes off and it fails.
After reading this forum, I was wondering if I have a faulty ELM 327. I got this one:
Modified EML:
* Please note that this ELM 327 HAS been modified to resolve the connection problems reported on the home page of MultiECUScan / FiatECUScan
But now I'm not so sure. So here are some images of the board. Could someone please tell me if it's alright?
Thanks in advance
In any case, your interface does not have the problem described in this thread
So this resistor must be removed for other ELM Interface
is not available in your ELM
And the adapter you should not use the service read.
