hardware key
vapaota
hardware key
Post by vapaota »
en fait, qu'est-ce que c'est ?
comment ça marche ?
où la trouver ?
merci de vos réponses.
in fact, what is it?
how does it work?
where to find it?
thank you for your answers.
Translation added by s130 -moderator
Re: hardware key
I do not understand you.
Can you be more clear?
:roll:
vapaota
Re: hardware key
Post by vapaota »
to register the software, you must enter a code "hardware key."
this code, I did not and do not know how to get it.
So since multiecuscan works only for registered version of my vehicle, I'm a can stuck.
Re: hardware key
The registry is very simple
- Install Multiecuscan 1.4 on your laptop
- Start Multiecuscan
- Press Registration (bottom left above setting)
- Note down the hardware key
- Jump to www.multiecuscan.net
- Click on "Buy Ried rest Lincense"
- Give your Hardware Key there a
- Give a valid address
- Pay € 50 for a predetermined way
- Some time later, you will receive a license key by email
- Paste this into the software "registry, license key"
- Multiecuscan Join now, it will appear at the top left.
vapaota
Re: hardware key
Post by vapaota »
Thank you for your help Eddy, it was actually very easy.
However, I have another worry: I can connect to the motor module, but not the service unit "please check ELM 327 and the configuration of your serial port"
the test function returns me ok all tests.
Panda 1.3 MTJ Marelli 8DF CF5/EOBD
Albert
I'm perhaps not the right section, I do not speak or read English, I apologize.
Re: hardware key
Hello Albert
No problem, my English is also not very good :)
The problem is that your ELM interface can not read CAN bus
This is a problem of Multiecuscan
Just look at the posts in this thread
viewtopic.php?f=5&t=1493
in the back pages you find solutions for your problem.
Otherwise, an alternate image of your board, and I'll tell you what to do
vapaota
Re: hardware key
Post by vapaota »
hi Eddy
if I understood, I must destroy my case ELM to change.
I see no screws or opening this device.
http://imagesia.com/imgp1129_88so
Du kanns't Mir auf Deuch antworten. Verstehe ich besser.
Albert
Re: hardware key
Post by s130 »
There could be screws that hold the two halves of the case together underneath the label.
Run your finger firmly over the label feeling for round depressions.
Failing that then it is probably a 'snap-together' case which will require careful prising apart. You MUST check for screws below the label first though otherwise you will badly damage the case if you try to prise it apart.
vapaota
Re: hardware key
Post by vapaota »
There were actually four screws under the label, but the system does not resemble what I've seen on various forums.
http://imagesia.com/imgp1130_89l5
http://imagesia.com/imgp1132_89l6
Albert
Re: hardware key
Hallo Albert
Multiecuscan kann mit deinem Interface keinen CAN Bus lesen
ein Widerstand stört diese CAN Signale
entferne den rot markierten Widerstand und dein ELM Interface
ist auch CAN Bus fähig
Gruß Eddy
imgp1132_imagesia-com_89l6 markiert (640x480).jpg (214.75 KiB) Viewed 10763 times
