Posts: 1350 Joined: 19 Feb 2011, 17:43
Post
by Alfaeddy » 17 May 2013, 13:39
Hello acafaro
Remove the Resistor in an red Frame , and your ELM Interface
can read now CAN Bus
la foto markiert.jpg (245.01 KiB) Viewed 10825 times
Post
by Alfaeddy » 19 May 2013, 22:39
Remove the Resistor in the red Frame , and your Interface can read the CAN Bus
6126927B markiert.jpg (127.37 KiB) Viewed 10809 times
Post
by Alfaeddy » 20 May 2013, 08:04
Hello Dimma_
Your picture is very small, even by larger I can hardly see anything.
Take a picture of the second bid directly from above with Macromedia
I need to read the designation of the components.
And pull the plug from the board
Post
by Alfaeddy » 20 May 2013, 13:18
Hello dimma_
Unfortunately, I still can not read the codes on the components!
And the plug is still plugged into the board!
But when I see the board as
I think you found a bug in the drivers or settings
because this ELM should be able to read CAN bus without modification
jackburton
Posts: 1 Joined: 21 May 2013, 06:14
Post
by jackburton » 21 May 2013, 10:05
Many thanks to ALFAEDDY for the instructions on This post:(
viewtopic.php?f=5&t=1493&start=330#p10608 ) from which i could modify my elm327 to be able to read can bus and others units on my fiat bravo 1.9 mjet. (But how was hard to unsolder r4!)
Post
by Alfaeddy » 21 May 2013, 15:26
Helloc Jackburton
gladly,
Prima this has helped you the post
One can easily destroy the resistor, if you do not have suitable soldering iron.
But we must be careful not to destroy the board
beAsty
Posts: 2 Joined: 19 Sep 2011, 17:28
Post
by beAsty » 21 May 2013, 16:33
Well I tried it with my ELM 1.4 device. First I removed the 120 Ohm resistor and inserted a blank "cable" -> no luck
Then I tried to add the 2x 100 Ohm Resistor + 560pF from pin 14 & ping 6 to pin 4 (GND) -> Still no luck.
Only engine + gearbox working on my Fiat Stilo Abarth Selespeed.
If anyone is selling a working device let me know :S
