Hi Yani
When calibrating a Selespeed a small error in the language setting, I noticed
In version 1.3, MES error indication was written in German.
Or was this changed??
Small error in the language setting MES 1.4
Re: Small error in the language setting MES 1.4
You are right. This is a bug in 1.4 and the message should be in German.
Hi Yani
This error has now disappeared after a few reboots. ?!
I do not know why
Well no translation error is more at this point
I do not know why
I have 1 problem with the language :
Settings :
- UI language : Espaniol
- Data language : Espaniol
But when I go in Adjustments [ F7 ] in left place I have : language Spanish [ Espaniol ]
and in right place I have :language English
How I put the language Spanish in right place ?
Tnx
Settings :
Tnx
- IMG_20130611_161534.jpg (317.55 KiB) Viewed 4757 times
Hello Socardea
This is not an error
because most of the error descriptions and explanations settings are still in English, only a few descriptions are translated
@ socardea
Yep. Eddy is right. No matter hat kind of language do you chose at the end in explanation window (yellow box on right side) you will get it in English.
It is the same for all other languages...
