What do I need to use multiecuscan on Fiat Stilo -03 1.9JTD?
Molsbrov
Post by Molsbrov »
I had engine fault message and now there is warning light on. I want to read and reset the fault codes, but I'm not sure what do I need (cables etc.) to use multiecuscan on my car, because I believe it's not OBD2-compliant. Car is Fiat Stilo 2003 1.9 JTD 85 kW. I would also like to get more information what's happening inside my car via multiecuscan.
Can anyone help me?
https://www.dropbox.com/s/mkgattairnjd1 ... .03.28.jpg
Re: What do I need to use multiecuscan on Fiat Stilo -03 1.9
Hello Molsbrov
This plug in your picture I do not know?
At which point the plug is to be found?
Your Stilo should be the 16 pin OBD connector to the left of the steering wheel in the fuse box
Your picture is in the engine room
You need an ELM interface and Multiecuscan to your ECU control unit / service, Can setup, body comp, etc. to read.
http://www.ebay.de/itm/260754573911?ssP ... 1423.l2649
For ABS, steering, xenon you need this Aapter
http://www.ebay.de/itm/151016679362?ssP ... 1423.l2649
So you can read all controls except the airbag control unit
this you need a KKL interface
http://www.ebay.de/itm/151015653820?ssP ... 1423.l2649
Molsbrov
Post by Molsbrov »
thank you really much for your reply. This plug is found right in the engine room, when looking in front of the car.
Thanks to you I was able to locate the right plug. It's indeed 16 pin OBD connector.
So this car is OBD-2 compliant?
Thanks also for detailed answers about the cables and adabters, it was really helpful!
P.S. I'm kind of interested what is that first plug? :D
-Molsbrov
Hello Molsbrov
By or for which the connector is I can not tell you
where the was plugged in?
for as the connector is very clean, it must be plugged in somewhere?
Molsbrov
Post by Molsbrov »
It just had cover on top of it and the cover was bolted on to the frame. So it wasn't really connected to anything. I didn't see where the other end was.
Will ELM-327 bluetooth-connector work on my car?
-Molsbrov
Your diagnostic port is inside the left of the steering wheel under a flap
There you can plug in the Bluetooth ELM
Molsbrov
Post by Molsbrov »
Yep, I found it with your help earlier :) And now I have the ELM-connector and was able to pull out fault codes. Thanks!
Still wondering what was that first plug :D
-Molsbrov
For me the plug from first post looks like (-) "minus" connector.
So all "-" wires are connected to one connector and that connector is connected to chassis with bigger bolt...
