Helo,wath resistor must remove from ELM327 v1.4 to work to fiat stilo 1.6 16v from 2003?I removed 2 resistor from picture circel 085831,i don't now but i do not know if i did well.
Thank's.
Thank's.
- IMG_20130406_143208.jpg (1.13 MiB) Viewed 7622 times
- IMG_20130406_085831.jpg (1.56 MiB) Viewed 7622 times
- Image0121.jpg (258.86 KiB) Viewed 7622 times
More photo with my elm327 v1.4,does anyone know if I did well taking out the two resistant from picture?,does anyone know what resistance must remove so I can use?
Thank's
Thank's
- IMG_20130406_143208.jpg (1.13 MiB) Viewed 7621 times
- IMG_20130406_143225.jpg (1.16 MiB) Viewed 7621 times
Hello Nelson
Your removal of the resistors was wrong!
Why did you do that?
There is nowhere where
This is you at your Stilo not the ECU can read a setting error
No resistance error
The users here in the forum should not be the same for the first difficulties you
Open Interface and remove anything.
This is a fatal error
Your interface have before you removed the highlighted resistors
All controls can be read apart from the airbag
No resistance error
Ok, if you stick to place the 2 resistors that I took that resistance must get her to work?
Thank's.
Thank's.
Hello Nelson
Yes, as I have already written !
With your ELM interface you can without changing anything on the board
Read your engine and ancillary equipment
I understand,i put back 2 resistor,but dont work,wath i must do?
Thank's for suport Eddy
Nelson wrote:I understand,i put back 2 resistor,but dont work,wath i must do?
Hello Nelson
I can not tell you!
Since I do not know if you know the right
- Drivers have installed?
- The Latency Time've set to 1
- Have made the settings on Multiecuscan / settings correct?
- Using the right adapter?
- Your ELM to the Soldery still works.?
Thank's Eddy,i hope to tell me somebody how to repair the ELM v1.4,i have Fiatecuscan 3.6.
Nelson wrote:Thank's Eddy,i hope to tell me somebody how to repair the ELM v1.4,i have Fiatecuscan 3.6.
Hello Nelson
Wiso an old version (Fiatecuscan 3.6?)
is the registered version?
or there is a free version?
About 1.5 years ago I had a user who also had connection problems
At that time, the problem was an illegal version of Fiatecuscan
With these versions, there are often problems
Hello Eddy,its a registred version 3.6,and when I try to connect appear message: SUITABLE INTERFACE NOT FOUND.
A GOOD DAY.
A GOOD DAY.
