highbrink wrote:Hi Alfaeddy,
Thank you for your reply
Sorry my mistake, i can access (connect) to the Engine Ecu
Answers to your question ;- Fiat Stilo Abarth Selespeed 2.4 20v - Model Year 2002.
Thank you Alan.
Hello Alan
For the ABS ; Steering and Xenon you need the Adapter
A1 green
http://www.ebay.de/itm/150964707626?ssP ... 1438.l2649
For your Airbag needet an KKL Interface switched
http://www.ebay.de/itm/150964798218?ssP ... 1438.l2649
or a normal KKL Interface and the Adapter A3 red
http://www.ebay.de/itm/150964700225?ssP ... 1438.l2649
and for the CAN Bus Problem remove R04 and you can read
Body Computer
CAN setup
CAN info
Yuker
Post by Yuker »
Thank you very much Eddy
stapy
Post by stapy »
any idea about the steps for Immo ?
zaka
Post by zaka »
Hi, friends. I have two items - elm 327 mini and KKL Interface switched. When I scan for device (F11) I get error "U 1601"
car: Fiat Linea 1.4 16V T-Jet
Need help. Thanks a lot.
elm 327 mini:
KKL Interface switched:
Sorry if this has already been discussed. )
Hello zaka
Your error U1601 means that the settings
Interface / COM port / not correct
Have you installed a driver for the FTDI interface?
Remove the red resistor R04 on ELM 327 mini
Then you can connect to the Can Bus establish controls
The KKL interface No error is present, this can be you
You need the KKL only for your ABS (Switch 1/9)
slka2 markiert.jpg (151.46 KiB) Viewed 9357 times
farris
Post by farris »
I have the samen scanner as Yuker in this post: viewtopic.php?f=5&t=1493&start=570#p11948
but when I try to connect to the ABS system I get errors on my dashboard screen: Brake system not available and ABS not available
When MES stops connecting, the ABS system comes back online.
Other stuff, like Engine ECU, body, climate control, service reset etc works fine
Only force regeneration of the DPF ends in an error (Unknown error)
What's wrong here?
zaka
Post by zaka »
Alfaeddy wrote:Hello zaka
Hello Eddy.
Thanks a lot for your reply and help. The KKL had a conflict with the settings of usb port on my PC. Now everything connects normally except for one thing. When I connect elm 327 to the diagnostic connector, on the dashboard the control lamp "fiat code" is on and the engine isn't started. if I connected at the working engine, all devices on the dashboard are switched off (except for the fuel level sensor). This is the way it should be? Thanks again.
farris wrote:Hello,
What's wrong here?
Hello Farris
If I understand correctly, all connections are working except for the ABS?
What kind of vehicle?
Are you using an adapter?
Which adapter?
farris
Post by farris »
Alfaeddy wrote:
Hello Farris
Which adapter?
Yes Eddy,
Everything works, except for ABS. When I try to connect to the ABS, I get errors on my dashboard, and MES says that it couldn't connect. Looks like the obd-adapter interrupts the communication between ABS and the car or something.
It's a Fiat Doblo 2011, 1.3 multijet. I only use the yellow adapter when I want to connect to the body and dashboard ECU, and no adapter when I want to connect to engine and ABS ecu.
It's a 2 year old bluetooth ELM (china), same as Yuker... I use it at 115200 baud, is that maybe too fast?
Hello Zaka
I understand this correctly, when you establish a connection with Multiecuscan
have you no longer display in the dashboard???
Except the fuel gauge?
All I can tell you nothing, if this is normal or not
Sorry
