MiTo MultiAir 135KM - proxy alignment execution failed (NAB)
bogas
Post by bogas »
Why proxy alignment procedure does not pass properly node airbags?
BTW - the position of the cruise control switch disables the ability to include daytime running lights in the menu on the dashboard. Cruise control still does not work.
Reading the CAN configuration data ...
CAN CONFIGURATION DATA:
6F 84 00 04 00 00 00 00 6F 84 00 04 00 00 00 00 41 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6F 84 00 04 00 00 00 00 09 04 00 04 00 00 00 00 6F 84 00 04 00 00 00 00 09 04 00 04 00 00 00 00 09 04 00 04 00 00 00 00
30 31 31 34 35 30 30 39 34 35 34 4F 55 54 50 55 54 2D 4A 49 54 20 10 09 13 6F 84 00 04 00 00 00 00 09 04 00 04 00 00 00 00 87 C0 71 07 67 10 61 11 B3 1F 00 00 07 05 00 84 06 2D 01 3C 00 00 01 00 7A 41 5C 0A 0D 00 00 00 00 00 00 00 00 37 02 41 04 08 00 00
CURRENTLY CONFIGURED CAN MODULES:
Computer Body (NBC)
Motor control (NCM)
Electric steering gear (NGE)
The instrument panel (NQS)
Radio (NRR)
Node braking system (NFR)
Climate Node (NCL)
Node deflection / lateral acceleration (NYL)
Node airbags (NAB)
CURRENTLY AVAILABLE CAN MODULES:
Computer Body (NBC)
Motor control (NCM)
Radio (NRR)
Climate Node (NCL)
Node airbags (NAB)
CAN MODULES THAT REQUIRE EOL PROGRAMMING:
Computer Body (NBC)
Climate Node (NCL)
Node airbags (NAB)
2013-03-03 15:30:29
CONNECTED TO:
Alfa Romeo MiTo 1.4 16V Turbo
CAN Setup / Proxi Alignment Procedure
CURRENTLY CONFIGURED CAN MODULES ::
Computer Body (NBC):
Motor control (NCM):
Electric steering gear (NGE):
The instrument panel (NQS):
Radio (NRR):
Brake Node (NFR):
Climate Node (NCL):
Node deflection / lateral acceleration (NYL):
Node airbags (NAB):
CURRENTLY AVAILABLE CAN MODULES ::
Radio (NRR):
Brake Node (NFR):
Climate Node (NCL):
Node airbags (NAB):
CAN MODULES THAT REQUIRE EOL PROGRAMMING ::
Climate Node (NCL):
Node airbags (NAB):
NOTE: The vehicle is properly configured. Proxi settings are not required!
ACTIVATE CONTROL ...
Knee airbag (driver)
Display of outdoor temperature on the board
Cruise control lever
Old value: invalidated
New value: Enabled
DONE
Cruise
New value: Enabled
DONE
Fog lights
Old value: Enabled
New value: Enabled
DONE
PROCEDURE 'ALIGNMENT' Proxi
Writing to module: Body Computer (NBC) SUCCESSFUL!
Writing to module: The instrument panel (NQS) SUCCESSFUL!
Writing to module: Climate Node (NCL) SUCCESSFUL!
Writing to module: Node airbags (NAB) FAILED! - Outside the scope of the request failed
EXECUTION FAILED
Cruise
Old value: Enabled
New value: invalidated
DONE
Old value: Enabled
DONE
EXECUTION FAILED
Cruise
New value: Enabled
DONE
EXECUTION FAILED
Alfa Romeo MiTo 1.4 MA Turbo Benzina, 135KM, MM 8GMF
bogas
Re: MiTo MultiAir 135KM - proxy alignment execution failed (
Post by bogas »
Yani, look at the report please.
I sent yesterday and today via the MES.
I saw your reports. Unfortunately, I cannot tell you why the airbag node doesn't pass correctly. This type of error is very rare.
Are the body computer and airbag control unit originally from this car? Or one of these modules is replaced?
bogas
Post by bogas »
Thank You yani for answer.
Yes, control units are originally, this is a new car from the dealer. When connecting to the air bags have incompatible error code iso. What else can I do to solve my problem? Do You can? Can I trust that the air bags will work correctly if needed?
Regards,
bogas
First of all - YES, the airbags will work properly. The PROXI does not affect the functioning of the airbags.
Do you have any problem with the airbag module other than the fact that it does not pass PROXI alignment? If you don't have other problems (like flashing odometer) then do not play with it. The airbag module is properly programmed at the factory and does not need to be PROXI aligned again (unless you change the body computer, but even in this case you don't have to re-align the airbag module).
bogas
Post by bogas »
Sometimes I have errors in BC like B1044, B1067 and rare B1044 and B1051 (before proxy alignment). Could that have something in common?
Why when connecting to the air bags have a choice between two control units?
Trying to connect with one gives a message that is incompatible with iso code.
I never had a flashing odometer.
bogas
Post by bogas »
When trying to connect the airbags have a choice between two continental drivers. The first reported error code like a bad iso.
Maybe this is the reason for the wrong alignment proxy? Can you try to swap the selection or delete it at all?
I sent you a full report from the MES.
I care about this because in the future I want to replace BC (cruise control and measuring resistors for low current circuits - LED).
Yani, please try to solve this problem.
bogas
Post by bogas »
Yani,
I found a solution to the problem!
During the proxy alignment may be no seat belt fastened. I have an extension cord plugged in all the time with the child seat belt.
After unplugging the proxy alignment of NAB has been made​​!
I have uploaded the logs.
