Help needed
amgart
Re: Help needed
Post by amgart »
eddy,
with my elm interface i can connect to ecu, but with the adapter plugged in my interface the fes send the message i post earlier. i´ve already seen that topic about the resistor, but by the interface that appears in those pictures isn´t the same as mine. so i don´t know what resistor to remove and what pins to solder the other resistors and capacitors. my elm interface works through Bluetooth and in those pictures for what i´ve seen, is linked by cable on the usb port.
Re: Help needed
I also think that this is caused by "the resistor problem" as noted by @Alfaeddy...
amgart
Re: Help needed
Post by amgart »
Yani,
Could you show me a topic or a schematic in how to Change My interface? My interface is a elm327 with Bluetooth....
Again, thank you all
Re: Help needed
In this thread
viewtopic.php?f=5&t=1493
are very many ELM interface described and what to change them.
amgart
Re: Help needed
Post by amgart »
:P Eddy,
Your the Best!
Re: Help needed
Nice that I could help :D :D
amgart
Re: Help needed
Post by amgart »
Eddy,
I thought i had My problem solved but no. I wich pins i solder the resistors and the capacitors? IN the topic that yanni Posted i could 't see what pins where.... :shock:
Re: Help needed
Has documented the procedure for the Yani in the first post is not necessary
No additional resistors and capacitors are soldered.
Since the platinum structure is completely different
It is only necessary to remove the resistor in the latter post.
amgart
Re: Help needed
Post by amgart »
Ok, ill try that. Later i post how it Works.
Eddy again no words ti describe how much i thank you for all your Help!!
Re: Help needed
It's nice if I can help. :D
