Grande Punto Cruise control aftermarket
fiatbravoemotion
Re: Grande Punto Cruise control aftermarket
Post by fiatbravoemotion »
luc wrote: Ok then is it possible with registered version?
Yes.
blueice_slo
Post by blueice_slo »
dimitar_ak wrote:Activated and fully functional except the dashboard led indication.
The problem was weak cable connection on Pin 41.
The same problem was here with me, cable on Pin 41.
Now is working and the LED light also.
carloslybra
Post by carloslybra »
I have the same problem.
How do you resolved?
My car have the cable in the two conector from factory.
Hi from Spain
blueice_slo
I made a connection with this manuals :
http://www.grandepuntoclub.com/forum/vi ... 32&t=55296
and
http://puntomag.fr/viewtopic.php?f=11&t ... 9b47d1260a
If you already have this cables, then you need just to activate CC with MultiEcuScan.
In my opinion there are 3 options:
1. If you already have this cables, then you need to install CC and activate it with MultiEcuScan.
2. If you don't have cable, you need to install them, install CC and activate it with MultiEcuScan and the LED light don't work.
3. If you don't have cable, you need to install them, install CC and activate it with MultiEcuScan and the LED light works.
LED light works in some cars, I don't know in which, I think that this is a question about what year the car was made. Mine is 10/2008 and it has new connetors for headlights and maybe different wireing diagram for dashboard, I don't know.
About pin 41: you just need to push the pin all the way to the bottom.
fiatbravoemotion
You are wrong. There is any rule for which dashboard has or no this led. It is a lottery. I found full installation with dashboard in the cheapest car without air conditioner and radio. I didn't found this in full option car with Skydome and subwoofer. What they have they put into a car.
carloslybra
blueice_slo wrote:I made a connection with this manuals :
and
Thank you very much for replay, I use the paid version multiecuscan to activate.
My problem is to make the Proxy Aligement it gives me this error:
Writing to module: Dashboard Node (NQS) FAILED! - Order of range error
I had the cables, yet again I sige wire and giving me the same error.
What is my problem?
Thank you,
blueice_slo
You didn't read my post well.
I'm not an expert and I have not claimed. This was just my opinion on all treads that I read in forums with this kind of problems with CC.
carloslybra:
I used ELM 327 v1.4 and yellow cable for activation (there are yellow, red and green cables, each has another function to allow working with MES and this car GP).
I activated without problems.
carloslybra
Thanks so much, my problem is the same:
Nodo Dashboard
I will surf the net to search information about that
carloslybra
I bought a new dashboard, and the control cruise started to work,
Thanks, to everyone
alexandru c
Post by alexandru c »
Does anybody know if the wires from the switch control that conects to the airbag and horn and radio control from steering wheel, r conected to the electric switch with a conector or r they part of the electric switch unit and they cant be detached and i must replace all the unit if i have problems with wires.
Thank you very much!
Have a nice day!
http://img134.imageshack.us/img134/9962 ... medium.jpg
