The problem of resistor is often described here is relevant only Multiecuscan, I have not heard of the other diagnostic software have problems with.
Otherwise, it is a different problem
Furthermore, this problem is not to find resistor to your ELM interface.
And the red LED will only show that the interface is receiving power.
the other LEDs flash only when transferring data
hello mr alfa i have the same bleutoot dongel as lutxana1964 witch risistor do i need to remove o only can find r4 or r14 r04 is not dare any suggestions?
tnxs best regards bace1978
Greetings to all members can somebody please give a solution to this elm My ELM327 works great with engine but i can't connect to the CAN bus used on alfa 147 1.6 ts
2012-12-03 14.52.24.jpg (1.44 MiB) Viewed 8190 times
2012-12-03 14.51.34.jpg (1.23 MiB) Viewed 8190 times
thanks for the reply alfaeddy !!!! Front side of my elm is the same as yincar on page 5 but rear is different you see on pics i have 4 resistor c10 c11 r26 r27
Normally, your interface to work in this type also in the CAN bus. In your red frame 2 resistors and 2 capacitors, these are also on the original schematic of ELM Elektronics, so I do not think of an error of these components.
If you find any other solution, you can still try and remove R26 and R27 for the 4 components are not actually required.
It would be an attempt
Hi all,
I recently bought a ELM327, but I can not connect to the engine ecu fiat brava 1.9JTD 105hp. FES with all correct test. but still will not let me. I do not know if it configuration problem or the cable.
the cable is this.
greetings and thanks for everything
2012-12-07 14.25.20.jpg (1.33 MiB) Viewed 8096 times
2012-12-07 14.23.01.jpg (1.29 MiB) Viewed 8096 times
