Hi Yani, I installed from CANtie card the 1.1R3 over the 1.0 I used with Elm/KKL. It came out registered, sees the Cantie on COM6 but no activity in car connection. I presume I will have to deactivate and reactivate with new code applied to interface ID. Is it?
(Driver installed as requirted, too, in configuration application I checked on multiecuscan3.4+)
installation of multiplexed 1.1 over the old registered 1.0
Re: installation of multiplexed 1.1 over the old registered
Yep! received the licence code, deactivated, introduced new code, it changed from "registered" to "multiplexed", tried on car and works perfect.
Thank you Yanis !
Thank you Yanis !
Well, maybe I forgot to tell you about this detail... Good that you resolved it by yourself.
